XREF's that display in Autocad do not display in Bricscad
This seems to be happening more frequently as of late and I'm not sure why.
Symptoms:  XREF linework that displays correctly/normal in Autocad does not show at all in Bricscad.  Auditing/ reloading/ detaching/re-attaching has no effect.
The most recent solution I found was to open the XREF(s), audit them, and save.  Re-opening the drawing that has has the attached XREF's seems to display the linework after that.  Obviously that little "fix" is not a ton of work, depending on how many XREF's you have, and how big the drawing(s) are.  Regardless, not having the issue at all would be preferable.
Sadly as I was just trying to fix the problem for a user as quickly as possible, I did not look at the details of the Audit.  I will do so next time.
Is anyone else experiencing similar issues?
