Disparity between Bris ICAD and CMS ICAD
I received a file created on BricCad from a friend. I recently downloaded a copy of Icad from CMS , but the file from the friend will not open. I forwarded the file to CMS, they also can not open it. Both are intellicad ( or so they say they are ) so IF ?? I can not even open a file from one version of ICAD , that is suppose to be the exact same version sold by another vendor, How can one reaonsable expect to be able to work with files in ACAD as well ??? Too much disparity for me to want to shed 250 greenbacks , before someone come forward with some solid answers. ;>(
  • It is far more likely that the file was corrupted during transfer (as email attachment or on disk) than for you have discovered an incompatibility between Bricscad and CMS Intellicad
  • But the thing is. Why can't I even open the file. The file was simply copied unto a floppy at my friends computer, it was immediatly tried and opened by a different PC within the same office, but then I bring it home and it will not open in my version of ICAD. The error received is >> ERROR - BUFFER OVERRUN<< what does that mean.
