Cannot create / Access denied" errors when installing / running BricsCAD
In some computer installations, the main user account may not have sufficient permissions to install (or run) BricsCAD. A quick work-around when installing BricsCAD is to right-click on the installation file (.exe) and select “Run as Administrator”. Assuming that your BricsCAD product is installed, but fails to start due to permissions issues, you can right-click on the product icon and select “Run as Administrator”, also.
For more information, see the BricsCAD installation support knowledge base.
