Print as PDF - %%u doesn't work as expected
Hello Community,
I've got a problem with PDF export. I've got a single line text with the code %%u to underline the text. BricsCAD shows the text underlined. But if I print it as a PDF with the Print as PDF.pc3, instead of underlining the text there is a bold dot in front of the text. No underlining at all.
See also attached images.
I'm working with BricsCAD V17.
Thanks in advance for your help,
Micky
