Lantek HVAC equivalent library
Good afternoon,
I've a customer interested in an equivalent for the Lantek HVAC library. Apart from unfolding it should add the extra material needed for the joint (pittsburgh, spot weld, etc.). He is particularly interested in the part attached.
  1. Does BricsCAD has an equivavant?
    If not, does it have a solution you recomend?
B. Regards,
elo
