Bonus Tools?
I just installed the 3.3.0002 version.How do I find the Bonus Tools?Thank you. -VM
Loading the menu If there is no icad.lsp yet, the installer will create one. It will contain the line (command "menuload" "bonus.mnu"). Icad.lsp runs automatically when icad starts. if the icad.lsp is already present, the installer will not overwrite it and you have to add the line manually. Icad.lsp now loads bonus.mnu, which loads bonus.mnl.
Well....Tried adding the line -- didn't work.When I do a search of my BricsCad directory for bonus.*, *.mnu, and *.mnl, I find no "bonus" file of any sort. Vaughn
Got if! See A. Vaernes's Sep. 25th post in "Version 3.3 Released" thread below: Reinstall using "modify" option.Thanks -VM
OK, Bonus Tools is working..."Isolate Layers" and "Freeze Layers" don't work. I get the message: "An error has occurred: Function cancelled".What do I need to fix?
Fixed it.I had two layer tools in my icad.lsp that apparently were causing the trouble.
