BricsCAD doesn't remember the last plot / print path?
As I get used to the software it's getting more familiar. I just learned the plot vs print command. Now for my next question that I haven't found an answer to. When printing is BricsCAD incapable of remembering the path last used? I figured out how to set my main directory to C:\documents\clients but I always return there. For instance I'll print viewport 1 to C:\documents\clients\clientname\site\pdf. But when I go to print viewport 2, in the same DWG mind you and only seconds later, it starts me back at C:\documents\clients and I have to navigate to the correct destination folder every time. Is there a variable I need to set up in settings to make sure that BricsCAD will return to the same directory while I am working in one file?
