Plotting to pdf/a-2
Does anybody know how to plot a set of layouts to a multi-sheet pdf/a-2 format?
I've done it to a simple pdf but as I convert it to pdf/a with PDF creator all the layer information is lost.
You should not post the same question twice.
Here you can find an overview of tutorials:
https://help.bricsys.com/hc/en-us/sections/360001580814-TutorialsIn the 'Printing & Plotting' section there is an 'Output as PDF' tutorial:
https://help.bricsys.com/hc/en-us/articles/360007714034-Output-As-PdfFor more info on the _Publish command:
https://help.bricsys.com/hc/en-us/articles/360006776533-Publish0 -
I tried to delete the previous thread as it wasn't marked as question but I couldn't find an option for it. My bad.
Regarding the tutorials you linked for, there is no information regarding my question: Is it possible to print to pdf/a-2 format, maintaining layer information?
There is a section called 'Layer information' in the documentation of the _Publish command. See link in previous post.
Thank you for your continued attention, but I know how to publish to PDF and to maintain layer info. My problem, as mentioned, is how to do this for a PDF/a-2 format.0
Oops, sorry. I didn't realize that PDF/a-2 is a specific PDF format.
Have you tried Ghostscript?:
https://stackoverflow.com/questions/1659147/how-to-use-ghostscript-to-convert-pdf-to-pdf-a-or-pdf-x0 -
Thanks. I'll give it a try.
@avscorreia said:
Thanks. I'll give it a try.I would also raise an Support Request with Bricsys. I think the option of being able to set the PDF format output is valid feature request.
CAD Concepts0
