Excel OLE Problem
I'm having a problem when I copied a table from excel to bricscad and printing it on pdf file. The excel table I copied becomes OLE on the bricscad then when I printed it on pdf the table becomes all black. Is there any way I can fix this one? Thanks in advanced.
OLE will consistently provide problems and should be avoided. Instead try using a linked CAD table object.
- Issue the TABLE command.
- Right side, choose 'From Data'
- Dropdown choose 'DataLink'
- Choose 'Create New'
- Give it a name.
- Click [...] to select file.
- Choose desired area at right.
- Click OK until prompted for location.
If that doesn't suit you, take a look at DotSoft's XL2CAD.
At least up to v14, I can second the advice that OLEs will create problems. The output may be missing, pixelated, or as you encountered, all black. I think the only reliable way to have Excel data in BricsCAD is to get the data into a native BricsCAD table.
-Joe
