(missing: DWG to PDF.pc3)
Every time I go to print I see the following: None (missing: DWG to PDF.pc3)
To print I need to change the print settings to print as PDF.pc3 and adjust the page layout every time. I want to be able to just print the file as I would using AutoCAD. I've been told that the string "DWG to PDF.pc3" is a feature of AutoCADs built in driver but not supported in BricsCAD.
Does anybody have any suggestions for me? Is there a way I can import the driver from AutoCAD and incorporate it into BricsCAD? How would I know what file to look for?
Thanks in advance, this is really frustrating.
To resolve you can make a copy of BricsCAD's "Print as PDF.pc3" and rename the copy to "DWG to PDF.pc3". Print as PDF is the BricsCAD equivalent PDF printer.
To find the folder location for these files go into SETTINGS and search for PLOTCFGPATH.
CAD Concepts0 -
Thanks
That will work a treat.0
