engineering software
This may be a dumb question but does anyone know if Intellicad is compatible with EaglePoint engineering software.
  • I have used Eagle Point Software with Intellicad for nearly five years now. (Intellicad is the drafting engine for the EP standalone). However, beware! Eagle Points older versions when running with Intellicad newer versions on Win 98 were real buggy!I have found that newer versions of both Intellicad and Eagle Point work well with Win XP and Win NT 4.0 SP6.
  • We have a VIP liscense with Eaglepoint and run Eaglepoint with Intellicad 98, Eaglepoint Graphics Engine (EPGE=ITC version of Intellicad 2000 or so Im told), Autocad 2000, and MicroStation for our state projects. Most of our office uses Intellicad 98, because the EPGE seems a little buggy and slow. Our copy of Bricscad Intellicad 2000 seems to work better than the EPGE but apparrently is not supported by Eaglepoint. We still use Bricscad for drafting though. I hope that helps. I would contact Eaglepoint for more info.Kevin
