Problem with print A3 format in Bricscad V20
Hello,
I have a problem printing A3 size on the HP OfficeJet 7110 when I buy a Bricscad V20. In the printer settings you can set the maximum A4 size (printer configuration.jpg) OS is WIN10. There was no problem in the older version of Bricscad V15. In other applications, the printer prints up to A3 without problems. Has anyone encountered such a problem?
I don't know if this is a setting problem of your operating system or Bricscad, but
if you print your file as PDF, you can send this document on any printer and size you want.0 -
This is true, but I cannot print directly from a CAD system. I don't understand why it is not possible to set in the custom properties of printing A3 format, which in the case of eg. pdf printing goes without problems.
