PEDIT and x-marker
If you use PEDIT command, and choose "Edit vertices", X-marker appears to show endpoint of different sections.X-markes is white. If You use white background, you can not see X-marker because it does not change the color. How can I change the X-marker color? (I want to use white background, as almost everyone, I guess)If this is a bug, it has been there since at least Intellicad 2.x.x.something.
