Push pull from a reference point
I want to push pull a solid from say 75.38 to 90 without having to calculate the distance, how would I go about that? In AutoCAD I use the command FROM, select the base of the solid & enter 90 for the distance, but I can't seem to do it in Bricscad. Thank you.
Try using the Push/Pull command on a 3D solid and press the Tab key while the command is active. It switches the input modes if Dynamic Input is ON from Extended length to Total length.
