Design approach pile component for piling box
Dear all,
I am trying to resemble the Revit example for a piling box as below
I have taken a U-profile and parametrized from a vendor catalogue and added a design table as follows
My nooby idea is to draw a rectangle polyline and project the component along and then to adjust either U-profil component and/or rectangle size in order to arrive at proper corner overlaps.
What would be a flexible approach to this matter?
Kind regards
Sebastian
My first approach is to insert the created component, then insert another attache them according to shape as below
And projecting the solids as ARRAYRECT:
Then I add a single component to finish the corner. I am not able any longer to edit properties (e.g. length) for a single pile. Better would be to preserve the ability to edit the length for every single item.
Why not creating a Block for one part and do an Array.
Is it that Revit offers you to automatically fill them around any Polygon ?0 -
@Michael Mayer
In Revit it seems to be called a line-based row ("Reihe Linienbasiert") which I would interprete as an array. One is able to scale dynamically, so it could be an _arraypath
The detail looks as follows. I interprete one pile as a component. They seem to be stitche to a group.
Seems like I need to learn about _arraypath and how to generate components to align properly0
