Publish without Prefix sheet title with filename
Maybe I am missing it but in AcadLT (And AutoCAD full version) I could change the pdf output filename to include or exclude the drawing filename when batch plotting/publishing.
Is this possible in BricsCAD? I want to use only the TAB-name most of the times.
Added: Maybe add the posibility to use (custom) drawing propperties. At least we want to do better then that other company, don't we?
I think this is a valid feature request.
An interim solution is a lisp that changes the layout names. Do Publish then rename back. It may be as simple as setting a UNDO mark for the reset back. I was just reading a post about writing the dsd file for publish using lisp.
https://www.cadtutor.net/forum/topic/76074-superpublish-accoreconsole/0
