Unwanted Line/Entity when plot PDF
Hi
I have create 3D model in BC and prepare drawing in layout.
However when Plot PDF, there are unwanted line/entity/dotted appear.
I believe this is the underneath model that suprisingly appear on top when plot.
I have leave enough gap in between 3D model but still these dotted will appear.
Do we have any solution for this kind of issue?
I do have alternative solution which is Flat these 3D model, converting it to 2D. But hoping there is possible other solutions.
Perhaps there are some setting that I need to configure so that the 3D models might not show underneath line/entity/dotted line.
in PDF
in Layout
in PDF
in Layout
Could you attach a small sample file where this issue is happening? It doesn't have to be the whole drawing, if it's sensitive, just the entities in the area where the dots appear.0
Hi Billie,Billie said:Could you attach a small sample file where this issue is happening? It doesn't have to be the whole drawing, if it's sensitive, just the entities in the area where the dots appear.
Thanks for the response.
Kindly find attached sample as requested.
I still facing this same issue with other 3D model in Layout tab.
