IntelliCAD 3.3.0009 DE
I have some trouble with the new version 3.3.009 DE. I tried to open some older drawings, but ICAD hangs up at the end of the loading. I could not try, if it is the same with 3.3.003, because setup denies installation of an older version. Does anyone else have the same problem? Could you help me?PS: Sorry about my bad english.
  • Dear Sir,Does this problem occur with all your older drawings? Please send us a copy of one of such drawings.You can re-install an older version of IntelliCAD if you first UNINSTALL the latest version. Go to CONTROL PANEL > ADD/REMOVE PROGRAMS, then select BricsCad IntelliCad and press the CHANGE/REMOVE button. On the SETUP window choose REMOVE. Now you can install the previous version of IntelliCAD.
