Insert bug
There seems to be a bug with the Insert command. If I enter insertion coordinates in the dialog AND check "Explode block on insert", the block is inserted in a seemingly random place
  • Well, there is a bug I reported earlier in this forum. The only way I can insert a block correctly is to have GLOBAL coordinate system active. Also, when creating a new block, you should be in Worl C.S. Does this help?Regards, Vaclav
  • No, this is not the same. I'm in WCS to the extent possible when working in Icad. This is specifically related to inserting a block through the dialog, with a fixed insertion point 0,0,0 AND "Explode block upon insertion" selected. The entities are not inserted in the right place.
  • we fixed this problem and it will be in the next update.regards, sander, bricscad
