DMBEND - example of usage?
Trying to use the new DMBEND, for instance applied to a box, but as soon as I select or draw a line, the command ends. Help is not helping.
Thanks
Thanks
The line must lay on the face of the 3D solid !!!
Help is helping...
...the red lines....
Thanks Sakko. Tricky command, now I got it working. The trick is to have the line a bit longer. If the line is coincident with the edge most times it does nothing (as I tried before). Same if you use the New line option and just pick the two vertices of an edge; the second vertex must be a bit away. For sure a command to improve and a better help..0
