Use PDF/A by default
When you "publish" layouts (from a sheetset of whatever), you can select "PDF/A" as output format. By default, "ordinary" PDF is selected. I'd like to make "PDF/A" (1b or 2b) the default, but can't find an option to do so. Is there any ? (of course I could save a sheet list in the publish dialog, and it would remember my PDF/A choice, but it would be less hassle if it was the overall default)
There is no option to change default PDF format in Publish dialog, only via saved Sheet list, as you correctly noted.
