RT click customize
Hi all,
For some reason my right click isn't working normally. I use rt click to cut and paste with COORDINATES. Now, when I select, I right click and it shows my selection AND THE PROPERTIES of the selection set. I have no idea how this was changed.
Any ideas on this?
Thx for any help.
  • Hi
    It seems you have enabled the 'QUAD'. Check your status bar click the 'Quad' text there. You can use your shortcut menu with the Quad provided you modify the settings for the shortcut menu to your liking. Goto settings and look for 'SHORTCUTMENU' and 'SHORTCUTMENUDURATION'
    With the QUAD on you can trigger the shortcut menu if you long press the right click button. That is where the above two settings come into play.
    Try a few combinations. And see what works for you.
    All the best
