Hatching is during print dominant and loosing cut around text.
Dear community,
when creating a hatching, the hatching is broken up to make the text easier to read. I can't get the hatching to retain this break when printing. No matter if paper or PDF print. How do I manage this? Pictures attached for explanation.
Foto_Layout → as it is in drawing
Foto_PDF → as it is in print!
Thanks for help.
With kind regards
Olaf Knauber; HDM AG
Dear Community,
we are using BricsCAD V24.1.07-1 with W10 and W11.
Dear Olaf, I observe this behavior when print via Print as PDF.pc3 or export to PDF in BricsCAD, but get a correct result when print to external printer, e.g. CutePDF. It would be useful to create a support request about the issue, so it could be deeper investigated.
A possible workaround for Print as PDF.pc3 could be using of wipeout under the text.
1 -
Isn't it a matter of Draw Order in Modelspace? Send the hatch to back, then everything else should be visible on top of it?
1 -
Thanks for your comments. We check it.
