Trim a TIN surface
Hi!
Is it possible to trim/slice the TIN surface so that I only keep the area inside the red extracted boundary (extruded surface)? I want to get rid of the TIN surface outside of the boundary.
use the TINEDIT command with the option Add bOundaries
: TINEDIT
Select TIN surface [selection options (?)]:
[Add Points/Add Point Groups/Add Breaklines/Add bOundaries/Remove Points/Swap Edge/Point Location/Point Elevation/Add Line/Delete Line/Remove Outer Edges/Minimize Flat Areas/Remove Elevations]: ab
Select entities for breakline: [selection options (?)]:
Entities in set: 1
Select entities for breakline: [selection options (?)]:0 -
an extruded surface cannot be used as a boundary, use a closed polyline instead !
Thank you so much Sakko, I didn't think you could use a polyline drawn on Z-level 0 as a boundary on a surface higher up, but it worked out excellent!
