CreateDC failed! (error 0: The operation completed successfully.)
I can't find anything on this. Can someone tell me how to fix? It comes up regardless of the connected or default printer, but the problem persists and has gotten worse, to the point where BC refuses to print
At which moment the error occurs, when you press Print button? Does it happen with any drawing and any printer, including "Print as PDF.pc3"? Which version of BricsCAD do you use? What happens if you try to use Publish instead of Print?
*FIXED*
NOTE I uninstalled/reinstalled my printer drivers and software (twice)
To answer your questions:
As soon as I press print.
All drawings
Latest V25. It started happening on V24, but clearing the error and carrying on was fine.
It happens every time when printing regardless of default printer including none, but I can still use cutepdf and Print as pdf.
Bringing up the page setup (right-click sheet tab) causes the error. Publishing to pdf does not cause the popup. Changing to printer and publishing causes the error at every step.
Thanks, C_C
Probably this was some driver related problem, as PDF printers didn't have the problem, it wasn't a general printing procedure error. I'm glad you could resolve it!
