Switched to new copier/plotter-how to change page setups across multiple drawings
This is for V25 for the record. I changed my template's page setups but that's not going to help all the "old" drawings. Publish can be used but it's not permanent. Bricscad could use a "porting over" of AutoCAD's dwgconvert utility. I'm not a lisp or script wizard, does Lee Mac still offer his services? Curious as to what the rest of you do when changing printers.
Google is your friend, do just that "change page setups autolisp" you should be able to find something. Where I used to work we used plot lisps so did not use page setups. Had different lisp for each printer.
1 -
Thanks Alanh, will look into it.
PSETUPIN
1
