Security setting
To set "security" level, type "security" at the command line."Security" is missing from the Tools menu. Ver. 4.0.0026 Pro.
  • just goto tool/customise click on the menu tab and then click reset down on bottom and it will show up.
  • security settings are for VBA. They are enabled you have -VBA installed - a pro license- menu reset to update the menu to the licenseregards, sander, bricscad
