perpendicular flyover snap
I cannot use the perpendicular flyover snap in version 4.0026 or 4.0029. The only way that the perp. snap works is if I type in PER before snapping to a line, this is the first time that I have had this problem with Intellicad. Is this a bug or just a simple setting that I need to enter?
I have just done a test on my recently installed V4Pro. The perpendicular snap seems fine. As a part of the test, I tried a perp snap to a line that was not two dimensional (i.e., all on same "0" elevation) and got an expected line that did not appear perpendicular.This version seems to be the best ever, but more time in use will be the test.Regards, TonyPS. The font problems I had encountered earlier are fixed. I am very impressed with the speed of the response to address our issues. Good job Bricscad!
