Undo
After some editing time, in Icad 4.0.0026, the undo command seems to have unexpected results.Instead of undoing the last command, it's undone some random previous command(s), sometimes loosing a large amount of editing time.Redo doesn't work after this.It happened several times by now.Someone with the same problem?
  • Similar problem occurred at my drawing under 4.0.0029 - after a minor mistake I wanted to undo about three commands - I entered U+Enter three times and after the third one, ICAD started to undo step by step my work of maybe 15 minutes of work. Redo certainly did not help. Quite 'funny' feature - one can't stop ICAD, can only watch the destructive work of undo command :-)
