green/magenta ghosting 4.0.0029
Entities using green color leave magenta "ghost" images in the former location when moved. All the ghosts go away with redraw. It seems to be related to the color green, and occurs in some drawings but not in others.Sorry for all the posts, I use Icad about 10 hours a day, so problems show up fast.
  • i find this problem in older intellicad 3 versions. It's indeed only with color 3 and not with other colors(set cecolor=3 and draw circle, pline with arcs..). With a circle , the afterimages resemble year-rings in a tree. Redraw makes the images go away. We'll get it fixed, but not with priority. regards, sander,bricscad
