Draw Order bug.
Suppose you have two identical lines one on top of the other. If you try to delete one of them, which one will be picked by the pointing device, the first or last drawn ? The answer should be - "The last one drawn. " Not so in version 4. It appears that the order of items drawn, keep the rule "First in, First out".
  • I, too have experienced this as well. I am using Win XP Home on Intel P4's.
  • The answer to the my question, how to delete the last drawn entity that covers identical one below, is very simple. Delete by selecting the entities by crossing and then remove the last drawn from the selection set by picking it with "shift - Left button" of the pointing device,and voila:-) Until this anoiyng bug is fixed, I think this is the only way.
