show an exact point location
when i want to fast find the cordinates on the start of line. if i use the Esnap the cordinates shown on bottom of the screen are still showing me the mouse position. any idea on how can i adjust the setting for the cordinate shown there will be the snaped??thanx.
To check the coordinates of a point use the IDCoordinates tool (IDPoint command) on the Inquiry toolbar. If this toolbar is not open, move the cursor to any toolbar, right click, then choose Inquiry from the toolbar list.The read out of the coordinates field in the status bar has three options:- 0: display the coordinates of the last point- 1: display the coordinates of the current cursor position- 2: display the coordinates of the current cursor position when no drwaing command is active and display the Length/angle of the line or line-segment when drawing lines/polylines.To alter the coordinates display, use the COORDS command and type 0, 1 or 2 at the command prompt.
To alter the coordinates display, use the COORDS command and type 0, 1 or 2 at the command prompt. Or press F6 to switch quickly.
