[Sp] Zoom Dinamico / Zoom Dynamic
Hi.In the english version, un undocumented (?)feature allows the use ofZ (enter) D (enter) to access the zoom dynamic , how can i access it in the spanish version?
I have not seen the spanish version. But in English version, from the top menu if you go to Tool then Customise and select the Aliases tab, you can assign/change what ever letters for whatever commands you want. Perhaps you could try that.
The D option of the Zoom command is hiden. Z D works in the English version but fails in the Spanish version because the is a Derecha (=Right) option.If you use _D (underscore D) it will work in the Spanish version.
excellent! thank you, i have not tried before the underscore in sublevels of the commands in IntelliCAD.gracias
