Script for creating search path
How can I create a script file that will configure search path for blocks, slides, menu files, lisp files etc.I need to create an installer that will configure these paths without opening Intellicad and configuring the same for each user.
  • If all users have the same version installed, I think the most convenient would be to create a registry file of the Intellicad config directory. From the properly set up computer, start the regedit app (Windows>Start>Run>Regedit) and browse to HKEY_CURRENT_USER\Software\BricsCad\IntelliCAD\Profiles\Default\ConfigRight click>Export this section to a .reg file on a common location. All you need to do on each computer is to double-click the file to "clone" the setup from the source computer.
