DDRECOVER
The list of improvements for version 4.1.0016 say that a new command has been added - DDRECOVER. It is not recognized. It's not included in version 4.1.0017 either.
  • It is included in an external dll, called R18toR15.dll.This dll is loaded in icadbrx.lsp. Icadbrx.lsp itself is loaded by icad.lsp.Please check your icad.lsp for the line(load "icadbrx.lsp")But the installer will not overwrite the icad.lsp file if it has been edited. So there are two possibilities:- move your icad.lsp out of the way and do an update of your installation(a repair for example).- or just add the line (load "icadbrx.lsp") to your icad.lspAlexander Van HeuverzwynBricscad
  • Thanks. Problem solved!
