Stopping multiple UNDO
Hello,How can I set ICAD to stop multiple undo as a default?ICAD.lsp = (command ".undo" "_a" "_off" ".undo" "_c" "_o") doesn't stop it any more. Thanks,V. McIlrath
oops. I'm using Pro ver. 4.1.0033.
There is indeed something wrong with single undo(undoctl = 3). Normal undo is not affected, but single undo is broken. We'll fix it.sander,Bricscad
Sander,Is there a way to save UNDOCTL = 1, or must one go through the Drawing Settings menu every time one opens a drawing?I'll sure be glad to see the fix.Thanks, VM
Can you put it in Icad.lsp? (setvar "undoctl" 1) Some variables are changeable this way, others not.
My ICAD.lsp has (setvar "undoctl" 1) in it, with no effect. When ICAD is running, and I type "undoctl" I get "UNDOCTL = 5 (read only)". It seems like "5" is hard-wired into the program.
