Some file can't not zoom extent
Dear sir.I meet some file can't not zoom extent. it show in wrong position.BricsCad IntelliCAD 4.1.0036.
Dear sir,Usually this is due to invisible entities, as for example an empty block. Could you send us a drawing which has this problem?kind regards,Alexander Van Heuverzwyn, bricscad
Mine are all likely to do that. Sometimes it seems to be a memory of erased entities. Often it's a phantom point belonging to a block, way off the block and with no apparent way of listing or changing it - I have noticed this behaviour since Icad98.
