ver 5
Will all of the lisp routines that I have in version 4 run in version 5? Is the command structure the same or did some commands change so that the calls to them in programming will fail?Thanks,Vince Popish
  • All of the lisp routines will keep working, and the commands remain the same. sander, BricsCad
