Managing and Navigating between ModelSpace and PaperSpace
Does anyone have a workaround the management and navigation between ModelSpace and PaperSpace similar to AutoCAD's bottom left file tabs?
To navigate between layouts move the cursor to the second field from the right in the status bar (tooltip = toggle viewport mode), then right click and choose the layout from the list.To toggle between Model Space and Paper Space in a layout:- double click inside the viewport to go to model space- double click outside a viewport to go to paperspace
Tip:To set the scale (zoomfactor related to paperspace) in a viewport, double click the viewport outline when in paperspace. You can now type the scalefactor in the SCALE field. You can type the scale facter in a X/XX format.
