Enhacments of Ver 5.0.0011
Sir. I don't think that removing the BROWSE and EXPLORE options from the INSERT command, is a wise one.No one should name a block after Command names, or Object names. It has to be clear that it is not allowed to a name a block with names such as "LINE" "CIRCLE" "MIRROR" "BLOCK" etc.
  • That cuts out possibly 100 potential block names, some of which would be quite common like box, donut, wedge... Would you have software which rejected those names so that drawings from others could not be read? A similar instance is when the word "varies" is required in text or a dimension and it can be a nuisance, but you can't just ban the word.
  • This would cut out much more words actually, and you don't know them all . What if you insert a block in Bricscad french, german, and so on?
