ACIS solids created in Rhino are not showing up in BricsCAD
I'm using BricsCAD v. 4.1.11.0 and I'm trying to import ACIS solids created in Rhino but nothing is showing up. Does anyone know why that's so?Also there is another problem with solids created in BricsCAD. When opening the dwg in ACAD 2000 some solids are on a different position.thanx in advanceTobias
  • Hello Tobias,may I kindly ask to file a support request and attach a drawing containing Rhino-created ACIS solids that do not show up, as well as a drawing that suffers from shifting of solids when opened in ACAD. This will allow us to investigate and provide solutions.Best regards,Hans De Backer
  • Ok, the files are on the way but I must say that even AutoCAD (being I don't know how many times more expencive than BricksCAD) can't handle the ACIS coming from Rhino. Ok, they WILL show up but thats it. You cant work with them. So I checkt a bit more on Rhino forums and I got a simple answer:Rhino can't handle ACIS!greetingsTobias
