Bad bitmap when paste to other application via copyclip
HiTo replicate:1. launch Bricscad to open some dwg file (I have sample files but can't attached here)2. ctrl+A to select all entities3. ctrl+C to copy to clipboard4. launch MS Excel5. ctrl+v to paste the drawing from clipboard to ExcelThe result of the paste operation to the Excel sheet is that the drawing's entities & words are badly deformed. The scale of the drawing is off, i.e., relative x & y coordinate of entity is off from original dwg. (With acad, the result is much better.)Is there a work around with Bricscad. Thanks for your help....kiat
