Draw Order
Draw 2 lines. Hatch a solid area over the lines. use the draworder command and send the hatching to the back. Start up paper space. The hatch then shows in front of the lines. Click in the viewport and type regen and the lines show back up in front. Go back into paperspace and redraw or regen and the hatch shows back up ontop. I have submitted this to support 3 times over 2 or 3 different versions already with no reply. THIS NEEDS TO BE FIXED. As it stands we cannot plot in paperspace with the hatch under the other entities.
Today we made a beta build available to our beta testers that includes the fix for this problem. Once this build is found satisfactory it will be made available to our user community.
I think this fix may have an unintended consequence. I just updated to 5.1.0014 and while in paperspace the viewport objects are not visible. Any objects drawn in paperspace on top of the viewport show fine but the viewport is not 'seeing' into the modelspace behind. I can double-click to 'activate' the modelspace in the viewport and upon regen it shows up, but when you exit back into paperspace, the objects disappear again.This only happens in roughly 30% of my drawings and the rest are fine.Previous versions did not have this anomaly and when I call up the same drawing in A#$%CAD, all is well.
