Cut & paste from Acad dwg
I have an acad file which when part of it is cut & pasted into Icad, loses most of the text and one of the inserts. The insert is a hatched circle. It also creates about 20 layers all called TXT (the layer the text was on). These layers won't purge either, even though they are apparently not being used. I have had bits of other cut & pastes from acad files disappear. Are there layer names to avoid?
  • this means more work but you could wblock that part and insert it with the insert command. Maybe it'll work that way.nuno gouveia
  • Could you please attach this drawing to a support request, we will gladly investigate what goes astray.Best regards,Hans
  • Sorry, I just now realised posts were not sorted by date. I got around the problem, when I come across it again or if I can retrieve that file (in its original state) I will certainly post it.
