Fillet solids
I get a break when I attempt to extrude an object into a sold then fillet one edge of the object. It can be replicated by drawing a rectangle and extruding it, then try to use fillet command.Is anyone else having this problem?Thanks in advance,Jeff Hall
I get this problem any time I try to fillet a solid. It seems like this has been broken and fixed a couple times over the various versions of Bricscad. It is creating a big problem for me because Bricscad is very picky about the creation of solids from curves by extrusion.
