Moving this item to theTop
If you have the undo command eliminate 10 minutes of concentrated work, once it is annoying. If it happens twice, it can really sour your day. I hope the programmers will please consider this REAL problem and will also move it to the top of their list.I too have had the occasional problem of not being able to select with window crossing (never with singular pick, but there is time yet). I sincerely believe that removing the zoom commands from the undo list will if nothing else help to isolate the undo and/or pik bug (besides greatly pleasing me). BTW the window crossing seems to work always if you use the option menu rather than the right-left method.I am not writing this to support request because it appears that there is sufficient notification of the problem at this site.
  • Undo is, and has been, a priority item.It also is by far the hardest item to solve, mainly because it is so hard to consistently reproduce an undo problem. Therefor, BricsCad spent months developings a dedicated monitoring system to catch undo problems.This undo monitoring is included in BricsCad versions starting from V5.0.0016. It is not activated by default, because it involves a bit of additional processing and writes log files, which incurs a small performance cost.Still, if anyone experiences undo problems, notably undo going back 'too far', we would highly appreciate if you activated the monitoring system and provide us with the log files after an undo error occured. It would be a big help in getting undo issues fixed and eventually help to improve the quality of life for all users.To activate undo monitoring, please proceed as explained in this Knowledgebase article: http://www.bricsys.com/common/knowledge/topic.jsp?id=143
