switching between overlapping viewports in MS mode
I have a viewport in paperspace which is completely overlapped by another viewport. How could I get to the viewport (MS mode) ? In Autocad, you use CTRL R to cycle between viewports.
  • Can you move or stretch the selectable one just enough to have a little clear area of each viewport where they do not overlap? Then they should be individually selectable just by picking within each port's exclusive area.
  • You can use the CVPORT command (actually it's a system variable). Typing CVPORT at the command line shows you which viewport is active within the current layout and allows you to activate a specific viewport.
  • Thanks for the replies. We just can't strectch the viewport to have its exclusive area because that just makes the display not right. FJ's idea of using cvport works for me. Great! Thank you very much!
