Saveas
In version 6 if the variable "DWGTITLED" is "0" then the command "SAVEAS" does not seem to read the varible "DWGNAME". Is this a bug or introduced for some reason.There still seems to be an intermittent problem with createing selectionsets where objects can be picked one at a time but not using a window.ThanksRick Strachan
This is correct. We fixed that. The fix will be available in the next update.
Thanks for the quick reply. Looking forward to the next update.Rick
