no copying between dwgs
When I try to copy from one drawing to another, most of what I'm trying to copy is missing. This is something that hasstarted happening recently so I don't if the new release is theculprit or not. For now the only solution is go back to insertingdwgs as blocks. Anyone else experience this?
  • Sorry, forgot to note that if I only picksome of the entities in a dwg copyingto another works fine. For some reasonpicking all or most of the entities causesthe error. For the record this is for version6.2.0006
  • Some minutes ago we released V6.2.0010 which contains a fix and an improvement for COPYCLIP/COPYPASTE operations.But... unfortunately the fix is not likely to influence what you experience: most likely this is caused by one specific entity in the drawing. During a copy/paste operation, a temporary block is created to hold the copied entities, it looks as if creation of this block is interrupted when this entity is added. If the entity is corrupt in some way, it could be repaired by RECOVER. If this doesn't help, then you probably hit a bug. If so, we would appreciate if you could file a support request and append the drawing.Kind regards,Hans De Backer
  • This will also usually work if you have problems copying inside a drawing.
