A Small Suggestion
I have noticed that when using the dialog box hatching in Intellicad (where you can pick the interior of a closed region), hatches are not rotated to align with the current UCS. When using the hatch command (where you have to pick a polyine), they do match the current UCS rotation. Would it be possible to change the behavior of the dialog box hatching so that it would rotate hatches to match the UCS? This is what Autocad does. It is helpful when hatching details in which a lot of pieces are rotated by the same angle (a sloped roof assembly, for instance). I know it is possible to just enter that angle in the hatch dialog box, but the UCS method is faster.Thanks.
